- Me_AgainExplorer III
IdaD wrote:
Yep. Some seem unable to comprehend this, but it's pretty simple stuff if you actually know a little bit about the components of the truck.
It is quite clear the RAM has separated the 2500 and 3500 SRW into separate categories with a very different rear air suspension between the two or coil springs on the 2500, including the lower ratings and no option for the HO engine.
Move over to Ford and they are almost identical. Chris - IdaDExplorer
Grit dog wrote:
Greene728 wrote:
Me Again wrote:
IdaD wrote:
Me Again wrote:
M.R.E. wrote:
Thinking about purchasing a "10 Ram . What is your opinion about this vehicle ? Is this the year they started using DEF ? Will use it to tow a 5th wheel .
How heavy/big of a 5th wheel? Generally 3500 SRW are much better for 5th wheels vs 2500's.
Chris
A SRW 3500 is nearly identical to a 2500, unless the 3500 is an Aisin. Same truck with a lighter rear spring pack, and you can supplement that and get the same end result - door tag be damned.
Much better my arse... ;)
Not anymore, no coil spring is going to match a leaf spring suspension. Times have changed RAM has taken two different roads with the 2500/3500's! Chris
You won't ever convince him of that. We've had this row to hoe before and it's starting again. What the engineers say, the door payload numbers, different designations by the manufacturer, etc all say doesn't matter. What I'm wondering is if I make a few mods if I can somehow make my 3500 magically be a 4500??? Seems to work for 2500's.
Well if you don't understand that class 2 and 3 trucks are for most intents and purposes the same vehicle then there's no convincing you either. Chassis, running gear, wheels etc are generally the same with the exception of rear suspension and in Ram's case another trans is offered in 3500s.
Class 4 trucks are generally a completely different chassis and as diesels, de tuned. Iirc, this is not true for some F450s from a few years ago, that are a beefed up 350 dually.
Yep. Some seem unable to comprehend this, but it's pretty simple stuff if you actually know a little bit about the components of the truck. - spoon059Explorer II
Grit dog wrote:
I would also not consider deleted to be a bad thing if you're not subject to emissions testing and out of warranty. In fact it cleans up the injection events by getting rid of the in cyl egr and results in the same mileage and performance of the late 5.9s that are so desirable. Thousands of deleted diesels running around that are not tuned, hot riddled or run to death as stated above.
While I don't necessarily advocate for deleting trucks, if one was going to do it, this era truck would be a great candidate. The EGR system is especially dirty these years and requires a lot of maintenance. The DPF, if not properly worked, can clog up and be an expensive repair.
Deleting these emissions systems can get you more power, better fuel economy and more reliability... but at the cost of significantly higher NOX output per gallon. Depending upon how you feel about the EPA, you may or may not care. You could argue that a 2007 diesel engine can legally produce the same amount of NOX, so what's the big deal... or you could argue that the significant reduction in NOX is a worthwhile benefit for a minor setback in mileage and power. - DodgeVoltageExplorer
I have a '10 3500 dually. As far as the engine setup, it can't be beat. Smooth, reliable and powerful. The mileage will be 8-10 mpg if your camper is very large. I get a little over 8 mpg pulling 19,000 lbs. I get about 15.5 mpg just daily driving. Not great, but it is a heavy truck. - Grit_dogNavigator IIIBack to your regularly scheduled program. Nothing wrong with a '10 Ram Cummins and they're among the best of the pre def diesels. As mentioned, know that they are the same chassis as 3rd gen Rams. Not a bad thing and very heavy duty, but Ram upped the ante in 2014 with a new chassis.
I would also not consider deleted to be a bad thing if you're not subject to emissions testing and out of warranty. In fact it cleans up the injection events by getting rid of the in cyl egr and results in the same mileage and performance of the late 5.9s that are so desirable. Thousands of deleted diesels running around that are not tuned, hot riddled or run to death as stated above. - Grit_dogNavigator III
Greene728 wrote:
Me Again wrote:
IdaD wrote:
Chris
Class 4 trucks are generally a completely different chassis and as diesels, de tuned. Iirc, this is not true for some F450s from a few years ago, that are a beefed up 350 dually. - Greene728Explorer
Me Again wrote:
IdaD wrote:
Chris
You won't ever convince him of that. We've had this row to hoe before and it's starting again. What the engineers say, the door payload numbers, different designations by the manufacturer, etc all say doesn't matter. What I'm wondering is if I make a few mods if I can somehow make my 3500 magically be a 4500??? Seems to work for 2500's. - Me_AgainExplorer III
IdaD wrote:
Chris
Not anymore, no coil spring is going to match a leaf spring suspension. Times have changed RAM has taken two different roads with the 2500/3500's! Chris - 45RicochetExplorer
Chrisspoon059 wrote:
As has been stated, no DEF and the older style frame. Be aware that pre DEF 6.7 Cummins has a lower MPG than the DEF versions... usually 2-3 MPG worse. Lower HP and torque than a newer model as well. For the right price its a great truck, but don't overpay because of the Cummins name...
X2 on both. Shop for a DEF truck. - IdaDExplorer
Chris
44,055 PostsLatest Activity: Dec 23, 2025
