westend
Aug 20, 2013Explorer
trail-explorer wrote:I would disagreee that there is a marked quality difference between the high-dollar regulated assemblies and the cheaper non-regulated LED's. At least in the quality of the illumination., most are using very similar diodes.hddecker wrote:
There must be something wrong with the LEDs that I bought, because it doesn't matter which way I plug them in they work.
Higher quality LED lamps aren't polarity sensitive, which is a good thing in the even a light fixture happens to have it's hot and ground wires reversed.
All the LEDs I am using from www.ledtrailerlights.com are the same as yours in the way they function, they work regardless of polarity.
It's very easy to change the phase of the supply, just reverse the leads from the LED to the fixture. I used the supplied adaptor's molex connectors so it is a matter of slipping apart the connectors and reconnecting with opposite orientation.
