RustyMacIntosh
Nov 29, 2019Explorer II
2 12v batteries---Mallard TT help
I'm not new to RV's, I've been using a 19ft Mallard for my jaunts over the past decade. I was gifted a 34ft Class A but it is too big, I prefer the TT. The motorhome will go for sale.
I struggle at times. Due to an industrial accident a decade ago, sometimes I need pointed advice to make sure I do not screw things up. Things happen when the brain is injured.
Going back to the Mallard, one aspect that always annoyed me was the lack of house battery(s). So before we leave again for a trip to Kansas from California I need to solve two issues.
1) Getting a charge to the house battery from the tow vehicle while traveling. I use a 99 Suburban. I'm not sure if I just need to install a 12v plug in the rear (I have rear AC so there is power there), then string a line out the back window connecting to the house battery. Or hardwire it from the pigtail connection at the trailer and Suburban. Not sure how to do this.
2) Issue two that I need to solve is installing two 12v batteries rather than one at the outside front of the Mallard. I am thinking, if I got this right, that I can put two 12v batteries behind the propane tanks. There is room. But hooking up the lines to the trailer I need not to wire it in such a way it is 24v. My guess is I need to run a hefty wire from both pos terminals to the trailer 12v. And likewise, two negatives to the neg connection on the trailer.
I have that right?
In the past, I always brought a couple of those 12v power packs. In the trailer running things such as a computer or whatever, I used those power packs. While I still will bring them, before I leave I want to install several 12v plugs inside my trailer.
One plug, to an inverter to run an electric blanket. Since I have a generic Fleetwood the insulation is not all that great. I do have a good working furnace and 14g of propane upfront. But....you know, tootsies get cold... A 60w electric blanket might suffice.
I have that right?
