Harlock's avatar
Harlock
2000 F250 will not shift into park
Has anyone else had the shift lever get a bit slack on them and won't go all the way over to park?
We have another 250 of the same era in pieces in the shop and I was looking at the column, there is a pin that engages the shift lever to the column and it might have worn a hole into a slot, or it's wear somewhere down the line to where the little teeth are that hold the column in each gear. Anyhow I thought I'd ask before really getting into things to avoid dead ends. I'm guessing this is a common problem. The truck only has 140K miles on it so it's an early wear item it seems.
  • Had some slop in my 2000 F350 last week and found those bolts REALLY loose. Easy fix less than one minute with correct tools and a mirror.
  • So the latter two posters were correct, that was the problem. I found helpful photos on the ford-trucks.com forums and fixed it in about 20 minutes. I cleaned and put low strength loc-tite on the bolts as should have been done in the first place. I'm glad this fix did not require any dissasembly of the column.
  • yeah. Tighten those torx bolts sooner rather than later. I watched my F250 roll in neutral across the street as I turned from my mailbox to go back to the truck
  • There are a couple bolts on the end of the column that connects the shift cable to the shift tube. They are a #30 Torx head. When they come loose you get this symptom.
    There is an adjustment in the steering column. Had my 2001 repaired at the dealer. Very common problem. I know it's not much help.
    If you are member at Ford-Trucks.com I'm sure you'll get the correct info there.
    S
