Desert Captain wrote:
Something is seriously wrong with that truck. The Hemi should pull your trailer all day long without even breathing hard. You have a little more weight with the 3/4 ton but not enough to make that much of a difference. A lot of folks here with Dodge half ton Hemi's pull a lot more trailer than you without a problem. Have you had the drive train checked? The power is there in the Hemi but is it getting to the rear wheels? What does the Dyno show the Hemi actually putting out? Quite the mystery, be sure and keep as posted as to what you discover. good Luck! :h
I have to agree. I used to pull a FunFinder 210WBS loaded to just shy of 6K with a Hemi Jeep Commander (and the Commander, also a
fulltime 4x4, is heavy, right at 6000 lbs, fairly close, I would think to your truck), same hemi, same 3.73 gears. Never had any problems pulling that load and it could have happily pulled more, never needed more than 4th gear at 4,000 rpms on the steepest grades at 45 to 50 mph. I have a friend that went out and bought the same setup (Commander and FunFinder), but, with a slightly bigger and heavier trailer (6900 lbs on the road) and his pulls just fine. I would have to think you have something more going on with the output of the engine or getting it to the ground... :?
