BenK
Apr 21, 2014Explorer
Lifted?
Over sized tires?
Both reduce ratings and efficiency
Automatics are hydro fluid coupled and has a 10%-15% or more slippage. Inherent
in how they work.
Why they invented the TC lockup to remove that slippage, but lost is the torque
multiplication of hydro fluid couple that a TC's design enjoys
That slippage is why ATF gets hot, mainly. There are also losses in the planetary's
and bearing, but minor in comparison to the hydraulic slippage (shearing of fluid)
Also, what are your weights and speeds/terrain/etc you drive?
Heavier poses more stress on the TV & components...therefore more heat generated
by the TC.
Over sized tires?
in how they work.
by the TC.
44,056 PostsLatest Activity: May 04, 2014
