tekman741
Apr 22, 2014Explorer
BurbMan wrote:The power steering and brake go thru a hydrolic booster which is on the main pully system. You'll notice that there is no brake booster behind the brake master cyclinder and to help with steering it goes thru a booster same as the brake google it.(2004 k3500 hydrolic booster)=ehow
tekman, not sure what the power steering pump has to do with trans temp, there is no collant circulating in the PS pump.
PA, normal temps should be 150, 175 when towing and 190-200 on a steep hill with the trailer. What I would suggest is having the cooler lines disconnected from the tans and power flushed separately to remove any debris.
Not sure about the 6.0 but on my 8.1 there are two coolers in series. the trans fluid goes from the 4L80E into the right side of the radiator, then from there into the aux cooler as pictured above, then back to the transmission. The radiator helps bring the trans fluid up to temp in winter since the coolant is hotter than the trans fluid and helps to warm it. The aux cooler on the front then helps to moderate temps.
The brake hydro booster on your vehicle provides additional braking power to help reduce the amount of effort needed on your part to slow down your vehicle. The booster works on hydraulic pressure generated by the power steering pump. When you press on the brake pedal, the booster creates additional force on the braking system. That, along with the hydraulic fluid in the brake lines, creates a tremendous amount of force on the brake calipers and pads.
If that pump starts to over heat then your coolant temp goes up and the first to be effected(explained to me by a mechanic) is your tranny temp. It's been a year since my repair and all is "cool" It's what worked for me Hope I helped?
Read more: http://www.ehow.com/how_5969469_troubleshoot-brake-hydro-booster.html#ixzz2zc0VBBPu
44,056 PostsLatest Activity: May 04, 2014
