cga0641's avatar
cga0641
2004 Nissan Quest
What kind and where should I mount an auxiliary transmission cooler on our 2004 Nissan Quest? Pictures of install?
The Quest has a Class 3 frame hitch, trailer brake box & I have a weight distribution hitch with sway control. I want to add a tranny cooler.
We are going to tow our 2005 Sun Valley X-treme lite (single axle 14.5' box.) approximately 2800# dry weight.
  • Adding a transmission cooler is a very wise decision, if you ask 10 different people what one is the best, you will get 10 different answers. As for how or where to mount the cooler, they come with plastic zip strips to mount them to the existing radiator. Just mount it on the outside of the radiator, not between the radiator and the engine. Also, make sure you run the lines so the fluid goes through the radiator first then through the cooler. Buy extra transmission hose, the kits usually don't come with enough hose. Good luck!
