StirCrazy
Jul 27, 2022Moderator
Atchafalaya_man wrote:
"Camper weight is 3324 Maximum when it contains standard equipment, 46 gallons of water, 56 pounds bottled gas, 6 cubic feet refrigerator. Consult Owners Manual (or data sheet as applicable) for weights of additional or optional equipment."
you know its pretty sad, this used to be the wet weight, read the statment again so standard equipment which is everything you need to go camping, full fresh water and propane and refrigerant charge. so realy all you would add is battery weight and your stuff. my 1991 slumberqueen was for the most part dead on and now is 120 lbs heavier with my solare system and LFP batteries.
No I know there are a lot of "mandatory packages" now days that add between 400 and 800lbs" but the brochurs say that so they shouldn't be a surprise at all. I don't nee AC on my camper so I wont have that as a aditional weight when I buy a new one but thats the way I use it that allows me not to have one. I like what bigfoot is doing with the hand written wet weight leaving the factory, although it can vary from the advertised weight aparenty its not by much as it is mainly to take up any diffeences in the fiberglass process and to acount for optional items, so you realy should have a good idea anyways of what its going to be around when your ordering.
44,071 PostsLatest Activity: Aug 16, 2026
