mileshuff's avatar
mileshuff
2007.5 Dodge 2500 steering wander?
Seems this is a common problem. Steering tends to wander. At highway speeds have to make constant minor corrections. I don't believe anything is worn out as this issue has existed since new.
Steering linkage was replaced with newer 2008+ design several years ago. No improvement for wandering although handling over rough wash board dirt roads improved.
Tie rod was replaced this year as part of a recall. No change to wandering issue.
Several have stated two issues. First is a poorly designed steering box with excessive play in the output shaft. Second is excessive flexing on the steering box mount. I've been told that installing a steering stabilizer to tie the frame rails together and eliminate flex may help considerably.
Anyone have this issue with a 2007-2010 Dodge Ram 6.7L 2500 and have solved it? If solution was installing a steering box stabilizer which brand did you go with?
This is the type of device I'm looking:
  • My local truck supply has a decent price for BD Diesels version that looks similar and decent reviews. Might just have a project for this weekend!
  • RICKIM's avatar
    RICKIM
    Explorer III
    If your a little mechanically inclined and have decent wrenches/tools, yes, it should only take you 30-45 minutes tops.
    Be sure to support the sway bar so you don't get whacked in the teeth with it. :B
    You'll need to grease the bearing after install also.
    I used a little anti-seize inside the bearing and also better washers, as the ones they give you weren't to my liking. Bolts were grade 5 but washers were not.
    Rick
  • RICKIM wrote:
    Then went to this, Click.
    Steering is much improved as far as tightness and responsiveness, and no wandering.Rick
    Is this a simple do it yourself one person job to install? Website indicates 1/2 hour install so I'm assuming yes.
  • I have had steering issues also and have been considering a stablaizer also. I replaced ball joints, tie rod ends and track bar and it seemed steering got worse. I had a steering box replaced a few years ago under warranty and after replacing all the parts my steering felt a lot like when the steering box went out. I was figuring that is what I would have to do again. One day I noticed my sway bar end bushing bolt was broken off and missing. I replaced both sides and it was a considerable improvement in steering. Might check yours also
  • rhagfo's avatar
    rhagfo
    Explorer III
    This has been an issue with Doge/Ram for years, the steering box brace helps! I also had bad ball joints. I also put Luke's link on my trak bar drives great now!
  • Check the track bar bushings. Cheap fix ($20) and an easy DIY.
    When mine did that, it was a worn steering box.
  • RICKIM's avatar
    RICKIM
    Explorer III
    I had a very slight wander but figured I was still driving a large truck so I dealt with it. What I ended up having more of, was a slight knocking in the steering.
    After some research and no dealer help, I started off with a Borgeson steering shaft......didn't fix it, then went to the up-graded 2008 front end track bar, pitman arm and drag link.....didn't fix it......Still knocking and slight wander.
    Heavy duty 1/4" steel. Very stout.
    While I had it apart I changed all the sway bar bushings to poly also.
    It was well worth the investment, and its a steering upgrade and improvement.
    Good Luck,
    Rick
