rhagfo wrote:
sjturbo wrote:
Thanks everyone! Please bear with me on this.
Regarding GAWR = 6010 for 2011 Crew Cab long bed if I'm reading correctly.
40G Fuel 280lb
generator 130lb
Hitch 206lb
Pin 1785lb
Add Batts 210lb
total 2611lb
I must be missing something here correct. Because this gives me a good window.
Regarding cargo cap forgot to check door sticker but spec says 2050lb.
Combined weight Passengers,dogs,280lb fuel,hitch, and pin weight is close to 2900lb! So what now?
Yes you are, your pin at 1,785 is the dry pin it will be around 2,200 to 2,500 loaded.
I think before anyone is allowed to join this site they agree that they understand NOT to use DRY weights in determining if a truck can tow something!!! Also it says it can tow XXX is another real issue.
