Old-Biscuit wrote:
IdaD wrote:
Old-Biscuit wrote:
Payload & RAWR if one cares about ratings.......
Otherwise you can justify being overloaded like using air bags (which do NOT add any capacity)
Ignorance is bliss!
Edit to clarify - the only difference between OPs truck and a 3500 is a softer rear spring pack.  That can be directly addressed with airbags and thus in this situation you can effectively add capacity with air bags.  Everything else between the two trucks is identical.
Common sense, people.  This isn't complicated.
Air bags do not add capacity.
2500 has 10,000# GVWR
3500 has 12,000# GVWR
BIG difference.
Correct..........it isn't complicated
Go with ratings or 'justify'
Technically I agree on the bags comment.  But they sure hold up a lot of weight on my truck with only two full length springs.
