sjturbo's avatar
sjturbo
2011 Ram 2500 6.7 tow capacity?
Hope I can get some quick responses on this as I am going to check out a 2011 Ram 2500 LB with a 40gal aux tank, with air bags. I have a 2010 Laredo 316RL I currently tow with a 2001 F250 (max cap 12500lb). I think I load to about 11500. Will the Ram handle the load? Does anyone know where the published specs on the 2011 Ram can be found. Thanks for the quick responses?
  • Payload & RAWR if one cares about ratings.......
    Otherwise you can justify being overloaded like using air bags (which do NOT add any capacity)
  • I put 18" on my 12 2500 CTD and would have no problem loading to the RAWR of 6200lbs. My tires are good for more. The 2011 2500 is a lighter rear spring version of the 3500. Same truck otherwise.
  • I have the 18" stock tires and they're good for 3640 per tire.
  • Ok, I have an added weight of 3 additional batteries, (total of 4@ 70lb) so increased pin weight of approx. 210lb or total of 280lb. The extra pin/hitch weight might be at the limit, but with the added air bags I should be good I think? This truck has 2016 18" wheels. May need to remove the aux fuel tank because I need room for my Honda gen ~130lb.
  • rhagfo's avatar
    rhagfo
    Explorer III
    Killer is the 6,010# rear GAWR!, based on the 17" wheels and tires @ 3,195#.
  • No problem at all, especially with the bags. I think you'll be pleased with the newer truck compared to your F250. My dad still pulls his little fifth wheel around with his 2000 7.3 and it's been a great truck for him, but it feels like a tractor compared to the newer diesels.
  • 2011 RAM 2500 Specs
    5th wheel trailer...PAYLOAD is going to be issue.
    Look at data sticker on door jamb for payload (cargo carrying capacity)
    That figure is MAX weight ---all passengers, all.any stuff in cab, all stuff in bed (hitch ---and that 40 gal fuel tank {7X40=280# plus tank} plus wet pin weight (2200 plus)
    Then RAWR......6000#
    S/B doable but close on weight ratings
