tegu69's avatar
tegu69
2012 GMC tranny issues
I have a 2012 Sierra 2500 hd, gas 6.0, auto transmission. I tow an 8000 lb fifth wheel. The truck pulls the trailer well and generally shifts through the gears fine, with an exception. When I stop in a rest area on the Interstate for a few minutes I shut the engine off. I then go to leave and accelerate on the entrance ramp. The transmission seems to hang in (I think) third gear. Most of the time, it is on a level surface and the truck is accelerating as I would normally get on the Interstate. The tachometer is at 5000 rpm, I let off the gas some to let it shift and it doesn't. I then get back on the gas to about 5500 rpm and it finally shifts. Since this only happens as described and otherwise drives fine, it has just been a minor concern to me. A couple of months ago, I got my oil changed at the dealership and I mentioned this to the service writer. He told me that since it only happens intermittently, that they probably couldn't duplicate the problem and he didn't know what it could be.
I am now within several hundred miles of being out of warranty and I will be making an appointment with a different dealership. I was wondering if anyone else had similar problems.
  • Type it into the net and see what threads pop up. Go to the GM site and search there or post your question.
  • The transmission is due for service in about 6000 miles (severe duty). I thought I would have it done now when it is at the dealer. My last truck developed a chatter when turning at times. I was told that the rear needed an additive which seemed to help, but it turned out to be a temporary fix and started wearing out the right rear tire. I just don't want to have to pay for something like a new transmission (or rear-end) when the problem could have started while the vehicle was still under warranty. Thanks, Ron.
    Thanks I'll look into it. (I must write slow)
  • I actually had the same exact issue with a 93 Dodge/Cummins. I know that doesn't help but eventually the problem became so common on those trucks that there was a TSB issued for it.
    I would research whether the same has happened for your truck.
  • Have you had the transmission serviced regularly with fluid and filter changes? If not I'd start there.
  • We have a 2007 at work that had done this. One time a transmission was put in and another time the TPS was replaced.
