rubsal70's avatar
rubsal70
2014 f 150
Help guys.
I'm looking to buy a new f 150 v6. Towing max is 6300 with gcwr 11700. Payload capacity is 1620. The TT that I'm interested is 4750 and will load it with gear n without any water. I'm looking at 5300-5500 of weight. Is this to much for the truck please advice
Thanks
  • I've drove all three of the new base V6 Full-Sized trucks.
    The Pentastar Ram with the 3.55 gears has a tow rating of over 7,000 lbs and has what I will describe as 'guts' from the moment you press the gas. The Ford 3.7 is nice and has power but it lives in higher RPM's. The 4.3 Chevy doesn't feel as powerful as the Pentastar.
    IMHO...in the battle of the base motors, the Ram 3.6 Pentastar wins Hands Down
    Or were you meaning the bigger motors?
    Thanks!
    Jeremiah
  • The only reason I'm choosing the 3.5 is because of budget issues. I would love a 250 but I cannot afford it. The 3.7 is nice the ecoboost engine but it's more than my budget. I might go to a dodge or Chevy. What do tall think
  • If you decide to go to something larger in a TT you will have to also change PUs. Why not buy a larger PU now and you can tow anything later. You can't have too much truck. I have an F250. Would never buy another one. If I trade in my F250 FX4 it will be for an F350 FX4. JMHO
  • I think it would be a great match. I love the current crop of V6 base motors in the full size trucks. 305 hp is in the 3.7 IIRC. Don't be shocked when the 3.7 revs to 7,000 rpm before it shifts out when floored.
    If you get one make sure you get 3.73 axle ratio...I think all SuperCrew's get 3.73 with the 3.7 V6.
    Thanks and good luck!
    Jeremiah
  • Hi,
    What you are looking at is not really a "Max" towing capcity. Is this specs for the 3.7L gas engine? The Max tow will have the 3.5L Ecoboost, have the ability to tow 11,000 pounds (give or take) and have a much higher cargo rating.
    You might be getting what is left on the lot or something.
    What is probably going to happen is you will have a 5,000 pound trailer with a 600 pound hitch weight, with only 1,000 pounds left to carry cargo, passengers and such.
    The "Tow Max" is rated at around 2,300 maximum cargo rating. The trailer weight rating is closer to 10,000 pounds.
    Because you are buying new, why not get the higher capacity truck? THen if you decide to upgrade the trailer sometime in the next 10 years, you will not need to upgrade trucks too!
    Fred.
