music69 wrote:
Check out the new payload specs for the 2014 Chevy/GMC 1500 trucks. Unless I'm misreading it, the "standard" 1500 4wd 5.3 crew cab (near bottom of page) will have a payload rating of 1957 lbs (vs ~1650 now). What's interesting, is that the "max tow" 1500 4wd 5.3 has a ~100 lb lower rating. Yes, the "max tow pacakge" will be available w/ a 5.3 and 3.73 gearing. Not too shabby...
If you look at the vehicle weight of the max tow, it weighs ~100 lb more than vehicle with out the max tow. So the max tow package adds weight without payload, but increases the GCWR by 1700 lbs.
