JIMNLIN wrote:
So that means if I throw out the 6400 gvwr on my 07 Chevy 1500 and just go by the axle weights I actually have 7675 gvwr. My front axle is rated of 3925lbs and the rear is 3750lbs.
Chevy determines your trucks GVWR and the GAWRs. Trucks out here on the roads don't use GVWR for how much loads the axles/tires can carry.
Are you sure the 3950 isn't a RAWR number. Generally the trucks front axle is rated less than the rear axle as the rear axle carries the load from a hitch weight.
Just took another look. 3925 is listed under frnt. Guess its built for a plow but I dont have the plow prep package don't even think it was ever offered with a 1500.
