bkcauley's avatar
bkcauley
2014 sierra 1500/ keystone cougar 33res
The truck has a 1608 lb payload according to the door sticker. Truck has the 5.3 6 speed auto and 3.42's. I plan on buying a airbag kit with onboard compressor. Think this trailer is to much for my truck? The only things that will be on my truck is me and a basically empty toolbox. Maybe 100lbs with a few tools. I weight 165. 26 gal fuel = 155-160 ish. I think I'm fine with trailer weight. Tounge weight is up there. But I am willing to relocate everything to the rear of the TT to keep the weight of the tounge during moves. Trailer in question. http://www.keystonerv.com/cougar-xlite/models/33res/model-mobile
  • bkcauley wrote:
    I'm fine with heavy weights. And it will get moved anywhere from 50-400 miles depending on where my next job is, every 3 months.
    With that type of travel, personal opinion only, which comes from doing what your about to try, it will not work out well 90% of the time. Wind will make it so you just won't travel on those days, but even a calm day the moment you think this is not too bad you will be headed toward the ditch. I could drive 3hrs tops, then have to stop and rest, the constant battle behind the wheel was too much for me.
    Again my experiance only but I am sure there are people towing more through the moutains with no trouble at all.
    No way I'd want to do it with that truck. I had a 2008 Silverado Z-71, with 5.3 and 3.73. Payload was right at 1600 pounds. It was not a very comforting rig for pulling a 33' 6k lb trailer. The trailer you are talking about is 3 feet longer and 2k lb heavier.
  • EcoBullet wrote:
    It might be OK for short local trips, but it is certainly a combination I wouldn't want to go very far with, especially in mountains or windy conditions.
    Agreed, I think it is too much trailer for your truck
  • It might be OK for short local trips, but it is certainly a combination I wouldn't want to go very far with, especially in mountains or windy conditions.
  • I'm fine with heavy weights. And it will get moved anywhere from 50-400 miles depending on where my next job is, every 3 months.
  • Really comes down to your comfort level and experience. You will get responses all over the map with some saying your way over and others who tow twice as much with no problems at all. If you bought it already, or really want it, nothing said here will change it.
    Personal opinion having hauled less with the same, I don't think your going to have much fun traveling. If your not going to travel or move it only once in a while 50 miles you could live with it.
    One more thing, if you relocate everything to the rear to try and make the tounge weight less you could set yourself up for a very bad experiance. Lack of tounge weight is the leading cause of sway, poorly balanced rv, your truck will not hold that trailer back if it starts to go bad. Your better off trying a WD antisway system to help balance and if your putting in airbags it will look fine.
