Wood_chip's avatar
Wood_chip
2015 Lance 2285 vs 2015 Outdoors RV 240 rks
These are my final two contenders before ordering.Both are very good. My tow vehicle is not an issue as I could pull much bigger than these.I do like the heavier frame, the underbelly clearance and the interior headroom on the 240 rks and the fit/finish on the Lance. Its a coin toss right now I think. Everyday I lean toward one or the other with no conclusion.Today the wind has shifted toward the 240 rks.
  • I have looked and like the Outdoors Rv products so maybe a little biased but a couple things for me jump out. Better size water tank on Outdoors RV is important if you do a lot of bush camping. Easier to fill up and not have to worry once you get in the bush than transport extra jugs. 14" Tires appear a little small on the Lance unless they can be upgraded. The other question to ask is why is the Lance 2000lbs lighter. I know they use Azdel etc. to help but at 2K I am sure there is more on the construction side to explain it.
    Those are just a few that jumped off the front page quickly.
  • No. The Lance AC is not ducted. The roof is flat with no space.
  • I like Lance TTs, but they don't have ducted AC - does the one you are looking at have it?
