- I don't think you guy's put enough miles on your trucks to go the 15k mile oil change interval. There's also a time constrant of 6 months that will time out and require the oil to be dumped way before you reach 15k miles.
I'm like some of you it's still a mystery what oil comes from the factory. I read conflicting and compelling stories about the Rotella vs. the Vavoline. Not sure why it has to be such a mystery. - Cummins12V98Explorer III"The oil change indicator is useless if you like your warranty.
From the book"
Please explain what point you are trying to make? - Cummins12V98Explorer III
eHoefler wrote:
Factory fill is with 15W40 Synthetic.
It's 5-40 since they don't know where the truck will end up. They only recommend the 5-40 after the initial fill if you live in a very cold environment. - Cummins12V98Explorer III
The Mad Norsky wrote:
I changed oil at about 3,200 miles on my new Ram.
First, I am NOT gonna run factory oil for 15,000 miles in a brand new engine.
Second, I, and I don't think anyone else around, really knew what kind of oil was in the motor anyway. Some said 15W/40 Rotella, others told me 5W/40 Rotella and still elsewhere I was told 5W40 or 15W/40 Valvoline Premium Blue.
One could not even add a quart, if needed, with any degree of confidence that I was actually adding what was in the engine.
So now I DO know what is in the engine. And, if needed, could actually add a quart if low. Although this appears very low odds to happen, as the vehicle has used very little oil to date.
Mind you, next change will be higher mileage for sure. Still not wild about going 15,000 miles but we will see how things go. 7,500 miles or so was about the normal change on my last vehicle, and that may be where I go with this one.
Factory fill is 5-40 synthetic. I will only run my oil for a few thousand as you did.
I will be running AMZ/OIL 100% synthetic 15-40 and FleetGuard Stratapore filter. At the end of my second oil change I will do an oil analysis to see how the oil and engine are doing. Then decide if I want to go the full 15K if the truck says to go that long. - HouseApeExplorerThe oil change indicator is useless if you like your warranty.
From the book
Oil Change Indicator System — Cummins® Diesel
Your vehicle is equipped with an engine oil change indicator system. This system will alert you when it is time to change your engine oil by displaying the words “Oil Change Due” on your Electronic Vehicle Informa- tion Center (EVIC). The oil change reminder will remind the owner to change the engine oil every 15,000 miles or 500 hours, whichever comes first, except for the Chassis Cab models that are using B20 biodiesel, which are 12,500 miles or 400 hours, whichever comes first. Failure to change the engine oil per the maintenance schedule can result in internal engine damage.
Your authorized dealer will reset the oil change indicator message after completing the scheduled oil change. If a scheduled oil change is performed by someone other than your authorized dealer, the message can be reset by referring to the steps described under “Electronic Vehicle Information Center (EVIC)” in “Understanding Your Instrument Panel” for further information.
Replace the engine oil and oil filter every 15,000 miles (24 000 km) or six months, or sooner if prompted by the oil change indicator system.
Under no circumstances should oil change intervals exceed 15,000 miles (24 000 km) or six months, whichever comes first.
NOTE:
• Under no circumstances should oil change intervals exceed 15,000 miles (24,000 km) or six months or 500 Hours, whichever comes first.
• Replace the engine oil and oil filter every 12,500 miles (20 000 km) when running B20 fuel (Chassis Cab Only).
If Chassis Cab models are operated with greater than 5% levels of Biodiesel, the oil change interval must not exceed 12,500 miles (20 000 km) under any circumstances. See the Fuel Requirements section for more information regarding operation of Chassis Cab models configured for use with Biodiesel blend (B6-B20) fuel meeting ASTM specification D-7467. - estesbubbaExplorerWith my 06 Cummins it was shipped with Valvoline Premium Blue and all I ever used. I would be surprised if they ship with synthetic now but could be wrong. I thought synthetic wasn't recommended during break-in even though the Cummins can be worked right away. Both Cummins and Blackstone said no reason to change oil earlier than 7500.
- eHoeflerExplorer IIFactory fill is with 15W40 Synthetic.
- The_Mad_NorskyExplorerI changed oil at about 3,200 miles on my new Ram.
Mind you, next change will be higher mileage for sure. Still not wild about going 15,000 miles but we will see how things go. 7,500 miles or so was about the normal change on my last vehicle, and that may be where I go with this one. - Cummins12V98Explorer IIIThe more you tow the longer the drain interval. My last oil change did not come up until at least 7,800 miles on my 11 HO Dually RAM.
I expect with the type of driving and towing I do the oil changes will be at a fairly high mileage on my new 15 RAM. - ib516Explorer II
downtheroad wrote:
Electronic sensors throughout the drivetrain send information about engine revolutions, temperature and driving time and other factors to the car's computer. The data is run through a mathematical algorithm that predicts when the oil will begin to degrade. The light comes on well in advance, giving the owner time to get the car serviced.
I follow the oil life monitor..But...Change it when it shows around 20%. And or, I also change it it gets around 8000 miles and still shows lots of % life left...kind of a combination between new and old school.
Others change oil at 0% while others still stick to the old 3000 mile rule..
I use the % left as a guide, but change it when it's convenient for me. I'm usually slightly conservative though, usually dumping the oil at about 5000 miles or so, even though my truck uses 0w40 synthetic.
44,066 PostsLatest Activity: Apr 16, 2026
