Mransons's avatar
Mransons
2016 Keystone Passport Slide
Hello,
First time posting, however, I am excited to be a part of this community now. I have a 2016 Keystone Passport 2810 BH. I have used it a few times so far and it has been great.
I took it out a few weeks ago and when I put the slide out, my wife said the carpet by the sofa was wet. It rained the previous week so I am wondering if I didn't put the slide all the way in.
When I bring the slide in, I usually push the button down until the motor starts to strain. Should I keep pushing it until the motor stops completely to ensure it is all the way closed and against the seals? Should I worry about any long term damage from the wet carpet?
This is our first RV so I just wanted to make sure. Thank you all for your help.
  • I have the Cougar which is also a Keystone product. One of the slides is the cable style like yours. I was told to retract until the motor strains and the lights dim. Very unscientific but it works.
    Did you bring the slide in while wet? If so that could be the source of the water. Since yours is a '16 I'm assuming it is still under warranty. If you can't determine the source yourself, get it back to the dealer and get it documented while under warranty since it might take a couple times in to figure it out.
  • Thank you for your reply. It does have cables. It seems like the right side of the slide seals completely up against the seals and the left side isn't as tight but appears to be touching the seals. If I keep pushing the button down, the left side will get even tighter.
  • Take a look on the outside of the slide. Does it have cables? If it does you are probably doing it correctly. It is always easy to check by looking at the slide on the outside and seeing if it appears to be completely sealed when closed.
    If yours has no cables you may need to hold the button until you hear the motor ratchet when fully retracted. Of course this is only guesswork. You really need to call your dealer and ask the proper procedure for closing. If you were doing it correctly, take it in and have them see what is causing the problem.
