ksss
Jan 21, 2019Explorer
Yep forgot to mention the headlights. Also the more comprehensive kits (IE expensive) like Cognito mimics the front suspension geometry. That is why you have to use their upper control arm and so forth. The ride is identical to a stock truck. It is an excellent kit. If the leveling kit is only a key or simply cranking up the T bars the geometry is not duplicated and the ride and tire wear attest to that. It pays to do it right if a leveling kit is an interest to you.
