ACZL
Apr 18, 2018Explorer
2017 F350 dually
Saw/found said truck online/out of state and seems like a decently equipped truck for a XLT. Supposed to have trailer tow pkg, so am thinking it should have sway bars as well. Factory sprayed in line...
mowingman wrote:
THe axle ratio should also be on the window sticker. However, read all the listed options, as some options will require a change in ratio, (which will show up next to that option). So, only checking the original ratio shown at the top of the sticker can be misleading.
The 3.55 is usually standard equipment with the diesel option.
With the 5th wheel prep package, you will get an RV plug on the left inside rear corner of the bed, as well as a dual plug on the back under the rear bumper. The back plug has 2 sockets, one for the RV plug and one for a flat plug.
I did not think that you could get a factory installed spray-in liner. That is a new one on me. Those are usually installed by the dealer at an aftermarket place.
