strikeu wrote:
Grit Dog and Travlingman,
I don't know what you're looking for as for "data". I had some other pages that I closed out where between the ones I posted and the others, there was enough data to make a trend in my opinion.
I would love to see the number of Powerstroke engines sold from 2011-2017, how each was used, the number of failures of each part, the number of miles each engine had on it at the time of failure, and finally the cause and remedy of each failure...however I seriously doubt that is available to just anyone. if thats what you are asking me for, I don't have that.
However I do NOT find the amount of data regarding the RAM engines with this part, as I do the Ford Powerstroke.
my turn to ask you where you see that Cummins is putting the Eurpoean made Bosch CP4 fuel pump on it's engines. I have one in the driveway but it's dark and cold right now, I will go out and see if I can tell in the AM
Can't speak for Grit Dog, but when you said you had data I was expecting numbers to back up claims such as number of failures, not just I saw a bunch of posts on a forum.
As far as build numbers, I would say that by 2017 there would be around 1.5 million 6.7 powerstrokes produced. Here is a link to the
500,000 engine produced in 2013. I think I read about the millionth around 2015 or so.
Ram went to the CP4 in 2019 models.
