Wagonqueen_Truc
Jan 22, 2017Explorer
towpro wrote:
wagonqueen,
you can go to the RAM body builders website pick your year and truck (17 is probably very close to 16 weights) than on left side you will see "camper guide" click on that. go down until you find your truck listed. (be sure to pick 3500, 2 or 4wd, match cab, bed length, engine, GVWR and seats. no field for SRW or dually, but that is already in GVWR field as SRW is less) I noticed they had a mistake and showed both 6.4 and 6.7 as diesel (3500's are 1/2 way down).
once you find your truck it will show you center of gravity info for truck campers. as well as "remaining cargo"
back on the main index screen, you can also click on the page that shows Base Weights/GCW/Payload/Trailer Tow
Very helpful. Thanks!!
