MFL
May 02, 2023Nomad II
Most RV trailers come with OEM tires that are just barely adequate to cover the axle ratings when inflated to sidewall pressure indicated.
Unless someone replaced the originals, with a way over rated tire, use the likely 65 psi max. You should have stated the tire size, load rating, and tire max pressure, for best answers.
Even a C-load range tire would be 50 psi, so yes 40 psi is likely low.
Jerry
Jerry
44,072 PostsLatest Activity: Aug 23, 2026
