jadatis
May 03, 2023Explorer
Then you should start from the basic data.
That is GAWR's and GVWR.but better is to weigh fully loaded(also the persons), per axle, better even per axle-end.
Then I can make a customised pressure/loadcapacity list for your tires, with build in reserves and per axle single or dual or per tire given,so you dont need to do precalculations before looking back in officiall lists.
The recomended pressure you cant read now, is calculated for GAWR with no reserve.
Need from tires next.
1. maximum load or LOADINDEX.
2. kind of tire to determine the maxloadpressure, but if AT xxx psi is given on sidewall, thats what I need. Loadrange is a system to give AT pressure.
3, speedcode, less important.
4. If ST
4. If ST
44,071 PostsLatest Activity: Aug 16, 2026
