JIMNLIN
May 03, 2023Explorer III
- ST205/75/R15
- LH-001 (Maybe a Model# ?)
- 8PR 107/102L Load Range D
- Max Load Dual 850kg (1870lbs) at 450KPa (65PSI) COLD
It is a dual axle travel trailer, 6150lbs dry weight.
I'll probably try 65psi.
65 psi is the best idea for a cooler longer lasting tire.
Those minimum pressures for the load charts work best for cars/trucks/suvs with tires at the front and rear corners.
Your tandem axle trailer tires are set close spaced and towards the center of the vehicle. They side scrub on every turn. Higher pressures helps hold the tires carcass and tread belts together as the tire side scrub on turns.
JFY...the "max load dual" indicates the tire capacity when used in a dual position as in dual on a truck (side by side).
Your trailer is a tandem axle and uses the higher 2040 lb tire capacity at the same 65 psi.
check out Tireman9 https://www.rvtiresafety.net/2018/02/tire-inflation-not-same-for-all-trailers.html
As a actual tire engineer he has the knowledge and experience to explain why different tire pressures are used our trucks vs our trailers. Day of reading on tires for our different rv type vehicles.
44,071 PostsLatest Activity: Aug 16, 2026
