mowermech
May 03, 2023Explorer II
You could always use the redneck/jack-pine savage method of finding correct tire pressures:
1. Load the vehicle to the "normal" load usually carried.
2. On a hard, dry, flat surface make some chalk marks across the tire tread.
3. Drive the vehicle for a hundred yards or so.
4. Check the chalk marks for wear:
a. If the marks are gone, the tire is properly inflated for the present load.
b. If the marks are worn away in the center, the tire is over inflated.
c. If the marks are worn away on the edges, the tire is under inflated.
NOTE: This method works for all on-road vehicles, and should be done with the tires cold.
44,071 PostsLatest Activity: Aug 16, 2026
