BarneyS
May 03, 2023Nomad
Sandia Man wrote:
ST tires are not to be filled based on weight as you would on passenger and LT tires, they perform best at max psi and that is the way we filled our ST tires for 3 decades of towing fifth wheels and travel trailers. With all the issues online and on forums about ST tires, we NEVER had a blowout across 4 different RVs and roughly 100K mile across the 30 year span. Below excerpt is from Tire Track website.
Special Trailer (ST) Tire Maintenance
Allowing inflation pressure to drop can dangerously overload a trailer tire, resulting in excessive heat buildup and possibly a blowout. And while not always resulting in immediate tire failure, even a short period of operating a significantly under-inflated trailer tire can cause hidden internal structural damage that can result in tire failure. Tire load capacity is reduced while tread/sidewall deflection and heat buildup are increased anytime a tire is operated without enough inflation pressure to carry its load. The chance of failure greatly increases if trailer tires are underinflated or overloaded.
I'm with Sandia Man. We traveled all over the U.S. towing our trailers with the ST tires always set at Max sidewall pressure and never had a single tire problem in over 30 years.
Barney
44,071 PostsLatest Activity: Aug 16, 2026
