mowermech
May 06, 2023Explorer II
Grit dog wrote:mowermech wrote:
You could always use the redneck/jack-pine savage method of finding correct tire pressures:
1. Load the vehicle to the "normal" load usually carried.
2. On a hard, dry, flat surface make some chalk marks across the tire tread.
3. Drive the vehicle for a hundred yards or so.
4. Check the chalk marks for wear:
a. If the marks are gone, the tire is properly inflated for the present load.
b. If the marks are worn away in the center, the tire is over inflated.
c. If the marks are worn away on the edges, the tire is under inflated.
NOTE: This method works for all on-road vehicles, and should be done with the tires cold.
This is ok to tell if a tire is grossly over or under inflated but literally makes no sense and has no bearing on the OPs question, unless he’s somehow stranded in the middle of Death Valley with an air compressor and no pressure gauge or some other scenario equally as ridiculous.
I have always been taught (by civilian and military instructors) that for safety you want the maximum contact patch between the tires and the road. So, for maximum traction and braking, I want the chalk mark to wear away evenly across the tire tread. If it wears only in the middle or on the edges, that means the contact patch is quite small!
I do NOT want that!
When the brakes (not breaks) are strongly applied, that small contact patch will slide. Not a good idea, IMO.
Of course, YMMV...
