Snowcamp
Sep 15, 2018Explorer
2019 Ford F450 options for camper use
I'm preparing to order a 19 F450 Lariat Diesel with pick-up bed to replace my 07 F350 for hauling 1160 Eagle Cap. I'm trying to confirm which option packages to add to the F450 that will work with my camper. We keep camper on truck 90% of the time and tow an enclosed snowmobile trailer. Hoping someone has experience with new Ford options and how they interact with camper and can give me opinion on which options to include in new truck order.
I'm a bit concerned about new overall height as my current set up only has about 1.5" of clearance to get through garage door. From measuring trucks on the lot compared to my 07, it appears actual truck bed floor height is the same in current 07 F350 (17" tires) and new F450 (19.5" tires). Per Eagle Cap new 19 F450 will carry 1160 with no modifications but they do recommend 3/4" bed mat.
The Ford descriptions and sales staff I have access to have given vague answers.
The one option I have decided against is the Ford sun/moon roof, as I have had the camper strike the top of my F350 clearance lights a couple times and do not want glass above my head.
The options I'm looking for advice on are:
1. "Camper prep" package ($180) from the description it sounds like all I will get on a F450 with this package is a sticker in glove box that says camper capable.
2. "5th Wheel Hitch Prep Package" ($500). Appears to be only way to get an in the bed 12V plug to plug in camper. On some internet searches I have found some claims that this plug can not actually be used for slide in camper as it will cause the trailer tire monitoring system to not work properly, may not charge camper battery and may cause trailer brake system to not work properly. I would like this option for re-sale but want to be able to use in bed 12V plug for camper.
3. "BLIS" Blind Spot Monitoring for truck and trailer ($540). Appears while carrying camper I may be able to use BLIS for trailer and side of truck warnings.
4. "Tow Technology Bundle" ($1970). Looks like this will give 360 camera system that may have some use while hauling and loading camper and will give trailer tire pressure monitoring after purchasing extra TIPMS valve stems for trailer.
In addition to the Ford options I plan to add Firestone rear air bags, Stable Loads bump stops (top leafs only) and Torklift tiedowns with Superhitch. I use this on current F350.
If you have experience with the new Fords and what is worth adding to 19 F450 truck order let me know.
Thanks
Scott
Thanks
Scott
