Camp_woof's avatar
Camp_woof
2019 Ram 3500 dually and loading a bigfoot 10.4 ...
TxGearhead (Brent) had asked what kind of clearance I had with the new rig, well, it sure is tight. It's really at the tailgate opening where there is the least clearance, between 3/8 and 1/2 inch if camper has not shifted (which it did in the photo). So the tailgate is the tightest point.
Didn't go that smooth ...
1. wrong model number tie downs ordered, so stayed night near Apache TC. Put me up free in nice hotel. Relaxed with a beer!
2. Next day, they figured that Torklift had no idea what they're talking about fitting to a 2019 3500 dually. Wound up having a bunch of holes drilled and used Happijac to get me on the way.
3. After 6 months of looking at Torklift web site a couple times a week, as I overnight in Portland notice they change their fitment and say brand new tie downs are being designed for my truck.
4. I plan to use the new Torklift rears, will keep the Happijac front. Bugging dealer and will bug torklift to get stuff at cost.
I need to practice loading, no way I feel comfortable doing this on my own! I hope to be able to unload in flat(how flat?) dispersed campsites, time will tell. Very nervous about this!
Driving south of Eugene on I-5 to Grants Pass, there's some hills. I didn't notice any sway at all with the factory airbags. Kept taking turns faster, no problem! I can notice some front to back movement, that's the shocks I guess.
Truck is a beast, love it! This year will be great for trucks as all 3 brands have new HDs. Can't go wrong.
Camper, disappointed in my inspection(!) because I found NOTHING wrong except one exterior compartment latch was tight. I wonder waht I didn't test thoroughly! Every other little detail seems spot on, not even a piece of trim seems off. Good job Bigfoot!
Back in CA working for now, will reunite with rig in Orgeon week of July 4 for trip. Keeping rig in OR till I retire and avoid CA taxes.
  • SidecarFlip wrote:
    I won't run the TL rear tiedowns (or the front) for that matter. Where we go, anything hanging down and out the the sides of the bed is an invitation to snag a log or rock. HJ's don't hang down or out.
    mine is a 2wd pavement queen. off road to me is my stone driveway. no problem here.
  • I have a 2018 GMC 3500 and a Bigfoot 25 c 94. I had to raise the camper 1" to avoid hitting the radius at the bottom of the tailgate opening. When loaded I have about 5/8" per side. In order to avoid hitting the side of the truck either loading or from shifting. I made front and rear guide blocks. The front ones are attached to full width, doubled up 2x4's ripped down to prevent camper from sliding forward ( I do not trust the two rubber bummers as the point load could damage the camper or truck bed). In the rear, the wedge guide blocks mount on a full width 1" board. The wedge blocks are 5" tall tapered for 2 1/2" to "guide" the camper into the exact centered position. Makes loading painless and no shifting during traveling.
  • I won't run the TL rear tiedowns (or the front) for that matter. Where we go, anything hanging down and out the the sides of the bed is an invitation to snag a log or rock. HJ's don't hang down or out.
  • See that taper in on the lower 1/2 of your tailgate opening? that started in end of model year 2015 duallys.
    I think its to stop the bed cracking at bottom corner of that opening with the weight of the dualey fenders added to bed.
    My AF 990 is also tight here. but on the AF they put aluminum angle on the front corners, and if your not careful it can hook on that button at top that is for tailgate lock. And yes my camper moves every time I put it in bed of truck, even with rubber mat and torque lift fastguns that are set correct.
    one trick to get it off the edge is to jack up the camper so the weight is off the bed, than and lower the close side first until it starts to put weight on bed, than lower other side to level. (it also helps if you can have someone push on corner of camper to move the needed direction as you lower it :).
    I been meaning to measure the space so I can put a board in between wheel well and camper to force camper over some. but once I load the camper, it seems to stay loaded until fall.
    I have to mess with this every time I load/unload since I don't have a level space I own.
