4x4ord
Dec 21, 2019Explorer III
ShinerBock wrote:
According to what is stated under the title of the article, 409hp and 775 lb-ft at the wheels. That is 13% drop from what Ford's advertised 475 crank horsepower which is inline with the usual drive line power loss, but the 26% drop from the advertised 1,050 lb-ft is way more than usual. Not sure what happened there.
Of course these are probably not be sustained power levels.
2020 Ford’s Super Duty Pickup 6.7L Power Stroke Dyno Test
As you've said something is wrong with those numbers. It is highly unlikely that the new Powerstroke is capable of 409 rear wheel horsepower and only a maximum of 775 lb ft of torque. I would put 0 confidence in those numbers but I don't think the lack of airflow through the radiator could account for it as peak torque should show up at 1600 rpm .... so if poor intercooler performance is limiting the engine's output already at 1600 rpm it highly unlikely that more fuel and higher rpm is going to fix the problem.
