Grit_dog
Apr 26, 2022Trailblazer
Well, if it's true that there is no plug n play harness for an aftermarket controller, then see if there is a physical brake light switch on the brake pedal arm. If there is, you're in luck, just have to do it old school and wire up the +, -, trigger (wire to brake switch) and brake lead to light connector in back.
While it seems silly, I can see this happening, as "most" trucks seem to come with a factory brake controller for several years now.
