Grit_dog
Apr 26, 2022Trailblazer
dcb17b wrote:
Fisherman, I did not crawl under the dash (I was looking for a starting point).I checked on line to see what the plug end might look like but ran into so much conflicting information. The tekonsha website says there is no harness,Ford says there is no harness available yet the e-trailer website(referenced by enblethen) says"it's right here and shows a picture. The picture they reference is not that of a 2022. Sooo there is my confusion. In the end I have made an appointment to have one installed and are going to use "points" to help soften the blow.If nothing else I want to warn those who are buying a truck without a factory controller that they will need one and can't just plug one they have in.
To your point, a new truck, if it didn't come with a pig tail to wire onto a brake controller to plug into the truck harness, you're probably correct in it not being plug n play for aftermarket controllers.
Again, if it has a simple, physical brake light switch (which idk anymore, could be integrated into the system somewhere), it's not difficult, just more time consuming to hard wire in your own controller.
