- bnred9ExplorerThanks again everyone, I will stay with 80 unloaded and see what happens.
- wcjeepExplorerG rated tires are rated at about 4800lbs each with 110psi. At 55psi, each tire is capable of about 2400lbs. Or 4800lbs total tire capacity on the rear of a truck that weighs about 2700lbs total when empty. Nothing wrong with more air pressure. I was looking for softer ride and flat tire tread (with chalk) when empty. Truck was a daily driver at the time.
I run my spare tire with Zero air pressure. No other way to fit on the truck with Superhitch. I have an onboard Air Zenith compressor. - bka0721Explorer IIDadwolf2 is right, check with the manufacturer of your tires. Slight PSI changes will change how the truck handles too, with the tires on your steering axle.
I run;
Continental HDR
92 PSI on Front
110 PSI on Rears
b - ISBRAMExplorerMine is always loaded, 75psi front the minimum pressure recommended and 85psi rear. Rides great and the tires seem to be wearing even so far.
- dadwolf2Explorer
wcjeep wrote:
Empty, fr 60psi, rear 55psi
Loaded, fr 80psi, rear 110psi
Too low IMO. Check manufacturer's inflation charts. I've never seen a 19.5" tire chart that went that low. - BedlamModeratorYou should not run less 75 PSI in tires. The tire beads can break away from the rim under lower pressure. I run 75 PSI when empty on the front and rear. When loaded, 80 PSI front and 110 PSI rear.
- billyray50Explorer80 psi front and 100 psi in rear loaded. Unloaded 80 psi front and rear..
- bnred9ExplorerThanks guys, this is all new ground for me. Hope to get out a lot more with the wife not working thus it was upgrade time.
Bob - jimh406Explorer IIII had the same tires and wheels on my SRW that I had with Gs, I ran similar pressure to wcjeep except for 95-100 rear loaded.
Just fyi, my F-450 has the same tire brand/model and the DRW are 80 front 75 rear for 225/70R19.5s Fs. I haven't bothered to lower pressure for unloaded. - wcjeepExplorerEmpty, fr 60psi, rear 55psi
