Redsky
Jul 03, 2014Explorer
Start with the air pressures specified by the truck manufacturer and on the plate inside the door jam. Do not assume that the tire manufacturer's load and pressure chart is correct for your truck - it is not!
If you drive the truck for a few thousand miles the tread wear pattern will make it apparent if you should run with less air in the front or rear tires. Under inflating tires is a good way to reduce handling and increase odds for a blowout with the extra flexing of the sidewalls of the tires.
44,066 PostsLatest Activity: May 15, 2026
