ShinerBock wrote:
dodge guy wrote:
Ughh! Spinning 4.30’s is easier all around compared to spinning 3.30’s. It’s basically the same as removing 4K lbs of weight from the vehicle!
Yes, as if the force my legs need to put on the pedals of my 8-speed(which changes the ratio to the tire) bike in short gear is the same as taller gear and it would have no effect on the friction material if there was a clutch on my pedals rather than a chain.
What if you look at it this way: If I have 4.30 gears and I’m pulling a trailer that puts me at 28500 lbs gvw and say I’m travelling 65 mph and let’s assume the power required to do this is 150 hp I will be in 10 th gear running at 1800 rpm and my Powerstroke will be feeding 438 lbft of torque into my torque converter. Now I come to a hill ... say a 6 percent grade. The power require to maintain 65 mph goes to 446 hp. My foot goes to the floor and transmission drops two gears to 8th gear. Now my Powerstroke is feeding 968 lbft of torque into my transmission through my overdrive clutches.
With 3.31 gears say I only lock out 10 gear and I’m towing that same trailer at 65 mph. Now my Powerstroke is turning 1506 rpm and I’m feeding 523 lbft of torque into the transmission on level ground (and if I was concerned about my overdrive gears I could lock out 9) When I hit the hill and my foot goes to the floor I drop to 7 seventh and my overdrive clutches are out of the equation.
You’re not going to come up with a more realistic scenario where an RVer with 3.31 gears is going to be putting more than 968 lbft of torque through the over drive gears.
