95jersey's avatar
95jersey
3/4 Ton 250, 2500 payload limitations (gas vs diesel)
Was thinking on eventually upgrading to a 3/4 ton (250, 2500), and as I do more research, I am not understanding the benefit of the diesel based on the numbers on paper.
For example, while the towing numbers for the diesel are usually a few thousand lbs higher on a particular model compared to it's gas counterpart, the payload goes down significantly with the diesel.
Based on the Ford 250, it has standard payload at 3100lbs with the gas motor, but go to diesel, and this number seem to go down almost 1000lbs. I guess this is because of the extra weight of the motor.
What is the purpose of such astronomical tow ratings with the diesel, if your payload prevents you from towing anything near those loads? it seems you will run out of payload long before you get to your tow capacity.
  • Keep in mind that if you have a lease vehicle, your leas might prohibit towing entirely.
  • Prime example why GVWR and Paylod (which is based on GVWR) are numbers used for mfg. warranty issues, Class Rating of vehicle and Registration concerns.
    Diesel vs Gas
    Ability to TOW/perform while towing
  • rhagfo's avatar
    rhagfo
    Explorer III
    IdaD wrote:
    Yes, lets do this again!
    Not the first and not the last!!
