- David_OkkemaExplorer
Steve_in_29 wrote:
Bedlam wrote:
The only bad thing I can say about the GM trucks is that they sit lower. Once you are in sand and start to drag your frame, suspension or axle, your day gets much harder.
Not sure about current GM products but in the past they also had less load capacity.
My 2007 F350 SRW has the same GVWR as a 2007 GM Dually....11,400 pounds.
not anymore - David_OkkemaExplorer2500hd gas 2011 or later Chev or GMC..diesels are heavy for off roading independent front end on GM is better off road then straight axle..2011 and later have heavier frame and are stonger for TCs but u will hear lots of opinions..Ive owned them all and have had the best bang for the buck with the chevs..I own both diesel and gas
oh and get some timbrens...that's all u need - Steve_in_29Explorer
My 2007 F350 SRW has the same GVWR as a 2007 GM Dually....11,400 pounds. - Steve_in_29Explorer
RWDIII wrote:
all the F350 that I have noticed have Commercial tags.Means more money for the State and you can use it for work
This varies by State. Here in CA ALL pickup trucks get commercial tags (pay weight fees to DMV) unless they have a truck topper or camper permanently mounted on them.
If you do this to avoid the weight fees don't ever take it off as they use different numbering then car plates so it's EASY for an LEO to tell if you are legal or not. - NEOKExplorerThe most important decision you need to make is to match the camper weight including all the stuff you load into it plus the weight of you and all passengers to the weight of the truck. If you stick with a pop up camper and know you will never upgrade to a camper above the capacity of a 3/4 ton truck it should do fine.
- BedlamModeratorThe only bad thing I can say about the GM trucks is that they sit lower. Once you are in sand and start to drag your frame, suspension or axle, your day gets much harder.
- mellowExplorerHere in MD they ding you more taxes/tags for 1 ton vs 3/4 ton, so take a look at that in your state.
Out on the beach which is what I do a lot in the summer 4x4 with my TC I mostly see Ford F250's being the most popular size. My 250 does the job well in 4x4 with a camper on the back.
I have noticed the guys with chevys do get help pretty quick, the ford guys like to be seen towing a chevy behind them back out to the blacktop, maybe there is something to be said about that. - wvabeerExplorerI bet your sorry you asked that question. I say get what you like if doesn't haul it right modify it so it hauls it and just stay within your rear tire capacity. The main thing is to have fun. Thats all that matters.
- RWDIIIExplorerall the F350 that I have noticed have Commercial tags.Means more money for the State and you can use it for work
- zcookiemonstarExplorer
RWDIII wrote:
Get the one you want,all the big three are good.
I got a F250 with HD springs,since in Ariz trucks over 10000 GVW must have commercial tags.
What does having commercial tags mean? is it just more money? are you limited where you can drive or park? I am considering moving to AZ. in the near future and am also considering a 350/3500 series truck.
44,066 PostsLatest Activity: Jul 25, 2018
