- VinsilExplorer
Steve_in_29 wrote:
JIMNLIN wrote:
Ford lists a rear axle rating of 6290lbs and MAX GVWR of 10K for an F250. The F350 SRW has a rear axle rating of 7190lbs and a GVWR of 10K-11.5K.
Actually Fleet Fords body builders specs shows four different RAWR for the F350 SRW 6.2/6.7 line.
1. 6290 RAWR gas and diesel
2. 6730 RAWR gas and diesel
3. 7000 RAWR gas and diesel
4. and one 7180 RAWR for the 6.2 gas reg cab 4x4 truck only.
The F250 has one 6290 RAWR for the reg cab 2wd gas truck only.
All other F250 gas and diesel configurations come with the 6100 RAWR.
https://www.fleet.ford.com/truckbbas/topics/2016/16_SD_Pickups_SB_Updates.pdf.
The F250 heavy service package uprates the the trucks suspension to the same specs as the F350 SRW truck.
Th point here, as my other reply, was if moving up to a F350 SRW watch which GVWR package the truck is plated at .....if the trucks GVWR is important to you.
While I agree people need to pay attention to what the trucks are rated at I believe you are confusing the spring rating with the rating of the axle. The link you provide lists only two AXLE ratings,
F250 - 6200lbs
F350 - 7200lbs
While the numbers you quote are what I see listed for the spring packs.
So no matter what spring package gets selected on an F250, it's rear axle isn't as strong as the F350's with the same spring rating.
No, same axle is used in both the f250 and f350...and they are rated for quite a bit more than that...more like over 11k lbs from Sterling or Dana...haven't kept up on which supplier Ford is currently using. - Steve_in_29Explorer
nomadictxn wrote:
If you get a 3/4 TON extended cab short bed or reg cab 8 ft. Bed you will have a better wheeler for off road especially with a gas engine. I know GM 1 tons can't be had extra cab short bed. Something to think about.
Ford's site shows their F350 SRW Super Cab (extended cab) as being available with either a short or long bed. - Steve_in_29Explorer
F250 - 6200lbs
F350 - 7200lbs
So no matter what spring package gets selected on an F250, it's rear axle isn't as strong as the F350's with the same spring rating. - nomadictxnExplorerIf you get a 3/4 TON extended cab short bed or reg cab 8 ft. Bed you will have a better wheeler for off road especially with a gas engine. I know GM 1 tons can't be had extra cab short bed. Something to think about.
- realterExplorer
805gregg wrote:
Get a 1 ton, because later you will want one, and for heavens sake get a long bed, you will want that also later, heavy duty short bed is an oximoron
Short and simple. This is the best advice. - JIMNLINExplorer III
Th point here, as my other reply, was if moving up to a F350 SRW watch which GVWR package the truck is plated at .....if the trucks GVWR is important to you. - 805greggExplorerGet a 1 ton, because later you will want one, and for heavens sake get a long bed, you will want that also later, heavy duty short bed is an oximoron
Grit dog wrote:
exhaustipated wrote:
PRodacy wrote:
I'd go with a 3/4 ton instead of a 1 ton. The camper you're looking at isn't heavy enough to warrant the 1 ton, and you'll get more suspension flex with the 3/4, which is important off-road.
X2. You don't need a 1 ton to haul a pop-up camper as they're generally not as heavy and won't be a problem with a 3/4 ton and the price difference will be thousands less.
Or hundreds less if you're talking apples to apples.
x2
On a Ford the price difference is LESS then $1K between similarly equipped F250 and F350s.
Going with an F350 also precludes any need for air-bags or other suspension crutches commonly applied to F250s.
WELL equipped pop-up TCs such as Northstar and Outfitter are NOT as light as people would think.
44,066 PostsLatest Activity: Apr 10, 2026
