ShinerBock wrote:
NC Hauler wrote:
wonder why they don't badge them exactly the same, if they're identical:h Sounds like Ford is ripping the consumer off if a 1 ton SRW truck is IDENTICAL to a 3/4 ton truck....hmmmm..So RAWR, GVWR and GCWR are different, but trucks are identical :h...
Do some reading in this thread and you will know why!
PS: Ram has done something similar in some previous and current models if you look at the bodybuilder guide.
Actually, it was sarcasm....I know a little bit about these trucks also, but more about Ram and GM/Chevy than Ford.....I read the entire thread...again...sarcasm.....doesn't come out as well in print...I just don't buy all the "exactly alike" from some when they're pushing the limits of their trucks when towing and claim that their 3/4 ton truck is exactly identical to the 1 ton SRW in every aspect..(except for GVWR, RAWR and GCWR...go figure)..
Again, on these forums we continually read how there is no difference, or not enough difference to merit getting a "bigger" truck to tow with due to the fact that a 1/2 ton is same as a 3/4 ton, a 3/4 ton is the same as a 1 ton SRW truck and except for the extra wheels, the 1 ton SRW is the same as the 1 ton Dually....The truck manufacturers are ripping us off and we help them if all the above is EXACTLY THE SAME.....
