tinner12002 wrote:
Grit dog wrote:
rhagfo wrote:
Atlee wrote:
For me, I'd rather have 4x4 and not need it, than to need it and not have it.
I have used my 4x4 a couple of times.
I have also loved it when I needed it. Coming home from the Oregon Coast 1st week of January 2011.
The other plus is if you don't lock the front hubs, you can put the transfer case in low range for backing into a space. I find this very nice as one host site we use, is backing uphill to the blind side.
Well now I have covered the 4X4, thoughts, I would not own a Ford/IH 6.x diesel. They just all had too many issues.
Except there's not a single 4wd HD pickup with true manual hubs anymore, unless you get a free spin kit. Even the super duty hubs are kind of for show. There's auto lockers behind the manual hubs. The manual hubs are just bling until the auto locking hubs malfunction. Although idk if there's a way to disable th auto and run with just manual hubs. That would be great for a factory 2lo setup!
There is a company that offers a wiring harness that lets you engage 4wh low and disconnect the front axle so you have the lower gear ratio.
You can still get a low spec Ford with manual locking hubs and a stick through the floor for the transfer case.
I'm not sure if the latest auto locking hubs are the same, but the older ones if you engaged 4wd, then got out and turned the knob to "lock" then back to "auto" the hubs would disengage.
Back to OP's question. I have had 2 wd pickups in the past and they were fine for what I needed to do. Now I wouldn't be without 4x4, but that's just because the road I live on goes to heck in the spring. I wouldn't buy a 2wd without a limited slip differential though.
