Yes I had the BPD one installed along with the OEM oil cooler. Runs fine, have no issues. Guy that did work was lead tech at a ford dealer, he also brought my truck up to date with the latest TSB's. 8-9* spread when cruising at 80 mph empty. I think there are several company's offering improved coolers, just depends on which one you want. While the guy was working on the coolers I had him do head studs and gaskets at the same time. I also changed over the caterpoillar ELC coolant and got away from the ford gold which is still thought as being the reason there were failures in the coolers.
