mccrawwf wrote:
Please give your thoughts, or the the best financial and safe move for the future. I have a 2005 Ford 3500HD 6.Ol Deisal truck that I pull a 34 ft. Jayco 5th. wheel. Iam aware of the problems with my truck and the more I read the sicker I get. At this point-98K miles-no problems. Based on 2 estimates Iam looking at 6K to 10K to fix the problems before they happen. What is best-trade or fix? If I trade Iam going to a Dodge Diesal. Iam 63 years old and hope to RV till around 75. My trips are limed to a couple of trips to SC a year.
Tks! Bill
1. Go to AutoZone and get a ScanGuage II.
2. Monitor the oil temperature and the coolant temperature. If they vary by more than 15 degrees once the engine is at operating temperature and at highway speed, that is your first sign of trouble.
3. If or when #2 happens, replace the oil cooler and either delete the EGR cooler if your state does not have emission inspection, or get an upgraded cooler. At that time, replace the head gaskets and the head bolts with head studs. Have the heads checked for warping.
4. Install a coolant filter. It costs about $150 and you can install it yourself, very easy process.
5. If you got a quote for $10K for the upgrades, you are being hosed. I had the shop do all the upgrades I listed above, put on a 4 inch turbo back exhaust, replaced all eight injectors (only one was faulty due to the coolant leak into the intake manifold, but I did that for peace of mind) I also added a transmission cooler and filter system. TOTAL COST was around $5500, parts and labor.
I now have a truck that I have full confidence in. It tows my fiver like it was not even there. And with the current low interest rates, I paid for the repairs by refinancing my truck, adding only another year to the note and dropping the monthly payment by $200 a month.
It's up to you. You'll get people who will tell you get rid of that truck and get (name of their favorite brand here). But once those modifications are made, WHEN you need to make them, you will have a solid truck. I've got nearly 170K on my truck now and couldn't be happier.
The key to owning a 6.0 is monitoring the delta (difference) in temperatures between oil and coolant. A large difference means a clogged EGR cooler which starves the coolant to oil based oil cooler. The EGR cooler bursts, puts coolant in the intake manifold, lifts the heads. If you aren't having those problems now, don't worry. When you see those temperatures start to markedly differ, find a good, reliable shop. DON'T take it to the dealer! (I'll bet that's where you got that $10K quote!)
Good luck to you!
