hilandfrog
Apr 04, 2012Explorer
westend wrote:
Last night, I was covering up the insulation board next to the heater area. In haste, I forgot to make an access hole for the water lines. No problem, I'll just grab a hole saw and do it after the fact, I thought. Then I started looking how the water lines ae routed and realized that I may be able to make a straight run from the water tank and water heater, along the wheel well, and tuck everything up behind the shower stall. This would make those holes unneeded and be a lot more unsightly. I can still use the holes for fresh air supply, stick a small computer fan in there to move some air, or just cover them up. I'll have to determine all of this when I get to the plumbing. There are a lot of little designing bits like this to keep in order, in resto-trailer land. ;)
There are untold # of things I see an easier way for AFTER I have glued then hit the staple gun 20 too many times:D
Much like only finding ones missing, NEEDED, tool once the replacement has been purchased.:D
The vent hole idea is grand, sucking cold air in from every direction and pushing hot air up and out, win win.
I still can't believe I missed the edging thing......:S
Repo
