westend
Jun 12, 2012Explorer
I finished up with the supply fresh water piping, today. 40 crimps later, all with a two bolt die crimper and all of the piping passed the pressure test. It was a relief to find that the water heater and toilet hold water, those were unknowns. I do have on small leak, in the little compressor that pressurizes the water tank. I will pull it and check to see what that is. From the location, on the bottom of the pump,pump chamber, I'm guessing it's a sticky or open relief valve. Now that the pressure test is completed, I'll go back and install clamps to hold everything in place.
Tricky area, supply lines to the shower and leading back around the shower stall to the bathroom:
Supply pipes exiting the back of the shower stall enclosure:
Bathroom sink supply lines:
Toilet supply line:
The damp looking stuff is the soapy water I used to pressure test the piping after pressurizing it with air.
Toilet supply line:
