westend
Oct 02, 2012Explorer
Thought I'd bump this thread up because I have a question or two. First, small update on the Hilton. I finished the heater piping and then moved on to the TV. I have a repairable Samsung LCD but don't know when that will get done or if it is worthy of the Cowboy/Hilton so I went down to Sam's and picked up a Magnavox LED lit 32". Happens that this is also the most energy efficient panel in it's class. Win-win.
I made a mounting board to span three studs:
Mounting arm attached to back of screen:
Game on:
Now on to the next poject and this has to do with those questions. I'm going to build an insulated and heated enclosure around my single waste tank. I plan to do this with a steel frame, aluminum cover panels, foam board insulation, and a heating wire device used to keep gutters deiced. The drain piping will be individually insulated and heat taped, also.
First question: Has anyone done this or know of someone that has?
Second: Am I overlooking anything fundamentally wrong with the general aspect or materials scheduled?
Third: What would be the easiest way to control operation of the gutter tape? It puts out so much heat that it will melt a 24' solidly iced gutter in a few hours. I know it's overkill but if an event like a full tank of waste sits in subzero climate for a few days, it may be nice to have the overkill available. In regular operation, it might only be necesary to use 10% of it's output.
Game on:
