westend
Jan 03, 2013Explorer
Finally made a little progress on the solar wiring. I installed the conduit on the side of the Hilton that will hold the 4 ga. wires from the combiner box on top to the distribution panel and the controller, below. This was a tight fit because I had a stud in this location and wanted to bolt the conduit clamps to that stud. There also happened to be a 12-2 AC wire in the exact center of the bottom entrance. I managed to just nick the wire when drilling the first hole. A bit of OEM (Oops Engineer Modification) and all is well. ;)
I did remove a little too much paint around the bottom LB on the conduit but I'll touch that up on a warmer day. I've got to visit a couple of electrical distributors to pick up the rest of the wire and sundry bits, also need to make the mounting rack for the panel.
